Whither self-hosted two-factor authentication?
Digital Independence Day was yesterday, and this month’s suggested recipe (in German) was to switch away from Microsoft and Google authenticator apps.
These are the authenticator app options di.day recommends. I can understand them wanting to provide folks with options, but I’d only want to use open source and not a platform. What do you think? Are there others you’d recommend?
Open source
Hosted but “ethical”
“Free”, but part of paid password app
The recipe itself feels overly complicated. Here’s my plan:
  1. install the new authenticator app (likely FreeOTP because I use apple) and open it up alongside my existing authenticator app (Google authenticator) and password manager (Nextcloud Passwords).
  2. work my way through the list on the old app, decide which ones I want to update to use the new app, make the update and save the recovery key to my password manager, and then delete them from the old app.
  3. While I’m at it, also update passwords in the passwords manager, and delete logins from sites I no longer use
  4. When the old authenticator app is empty, delete!
Just use 2fauth, a lightweight docker container that gives google authenticator a run for its money.
Hmm.. 2fauth looks interesting! I added a topic for it here. I don’t know, though.. is it safe?[1] Is this something you installed on your home lab, on your laptop, or in the cloud?
  1. Not sure why but this reminded me of one of my favorite Space Balls scenes! Must be my bleary eyed, caffeine deprived morning. ↩︎
I am actively using it every day.
it is hosted in cloud at https://2fa.32by5.com
I’ve been using the google authenticator app on my phone for so long that it feels strange to contemplate moving to a cloud-based authenticator. The phone is always with me and only I can ever access it. So moving to a replacement for that on my phone feels right.
That said, it is certainly less convenient than 2fauth on a daily basis. Having to reach for my phone every time I log into one of the sites I log into every day sometimes feels ridiculous!
Also, just having it on my phone feels a bit risky, especially because I do not use icloud to back up my phone. If I lost my phone I would lose all the 2fa authentication details and would have to revert back to the recovery codes in my passwords app.
As per usual you are turning my expectations on their head! :upside_down_face:
This is the exact problem it solves, it lives as a PWA on all your devices (or the ones you meaningfully care for) and is readily available for when you need it. I still rely on iphone for some services where proof of ownership is more valuable than convenience, for example second factor to both my hosting providers (hetzner and vultr) are not on 2fauth because if my cloud account was to get affected I’d have no way to retrieve it.
For services that support multiple authenticators, I lean on enrolling passkeys via face id, windows hello and also a TOTP via 2fauth.
Essentially it boils down to what you are trying to solve for, I don’t support change just for the sake of changing.
Expanding upon the previous reply, I see that you mentioned bitwarden, You may as well just host vaultwarden and use the official bitwarden client with it.
There is certainly a collectors aspect to making this particular change. It makes me feel good to delete big tech apps from my phone, and the google authenticator is one of the last google apps I have and use every day. Still remaining are Chrome (which I use only to log into google, which is rare) and Google Maps (for when Organic Maps fails me).
So far FreeOTP is working fine as a drop-in replacement. I’ve been switching to it each time I am prompted to provide a 2fa code from authenticator, and am keeping a list of sites I have switched already.
I won’t do that because I am not already using bitwarden, a “freemium” platform. I use the nextcloud password app for password management.
I’m glad to know about 2fauth and will consider it for some use cases. It’s super interesting that it has solved the problem of sharing 2fa codes with others, which I think can be useful for small teams or families that have to be able to help each other by logging into each others accounts. Many services that require 2fa don’t make it especially easy for someone to have a trusted backup helper.
But for my own purposes I prefer to just have a single source of truth for 2fa codes and am ok with the muscle memory of always using the same app on my phone for all of my accounts. And if I lose my phone or don’t have access to it, I have the backup codes saved to my password manager.
I absolutely do this too. :+1:
But that’s the vulnerability, known as “Putting all eggs in one basket“ about the same as reusing the same password everywhere.
Thinking about 2fauth again, because I am finding it inconvenient to not be able to copy/paste the code from FreeOTP to my laptop.
I’ve installed 2fauth at 2fa.kb2.org and will try it out this week. I’m having a strange problem importing my google authenticator codes to it. According to the docs, it should work to export batches of 10 and then import via qr code, but I get an error and am prompted to try again.
I’m intrigued by this ios app! Apparently it’s a PWA that makes use of your 2fauth server and works when the server is not available. This functionality is similar to the nextcloud passwords app.
