2FAuth - web app to manage two-factor authentication (2fa) accounts and generate codes
From the docs:
Why 2FAuth?
Most authenticator apps lock your 2FA personal data inside closed ecosystems tied to a single device, account or vendor. It is restrictive, not very agile, and quite time-consuming.
2FAuth takes a different approach to bring you control, privacy and efficiency:
  • Accessible from anywhere
  • You own your data
  • Integrates seamlessly with any authentication workflow
  • Built for both personal and collaborative use
  • Allows backup, import and export
  • Fully customizable
In front of your computer, without your smartphone, dealing with a code request? No problemo, just open 2FAuth in a browser to get a code, and voilà!
